请问 CH558L/CH559L 是否可以从用户程序跳转到Bootloader?
CH390:以太网控制器芯片
The following will do the trick.
#define CALL(addr) (((void(*) (void) (unsigned char*) addr)())
Then somewhere in your program use CALL (0xF400);
Note its Not the same as activate by HW contition but download
will work. Changing Config Options on the other hand will be
ignored.
