windows 10 64 bits driver PCI DUAL SERIAL
Hi, I'm from Brazil. I went to install a dual serial PCI card in my windows 10 pro
I've tried it with several drivers downloaded from the internet but none of them worked.
Can I send the correct driver? THANKFUL
A required entry is missing from the driver installation file for this device. This could be because the INF was written for Windows 95 or later. Contact your hardware vendor
PCI\VEN_1C00&DEV_3253&SUBSYS_32531C00&REV_10
Hello, according to your feedback, the pcie converter you are using is CH382, you can download the driver from this link: http://www.wch.cn/downloads/CH38XDRV_EXE.html
