int ADC_Temp(void) { UINT8 i; UINT16 AdcTemp=0; ADC_InterTSSampInit(); adclen = 0; PFIC_EnableIRQ( ADC_IRQn ); ADC_StartUp(); while( adclen < 12 ); PFIC_DisableIRQ( ADC_IRQn ); for( i = 2; i < 12; i++ ) AdcTemp += abcBuff[i]; AdcTemp /= 10; return ADC_GetCurrentTS(AdcTemp); }
__attribute__((interrupt("WCH-Interrupt-fast"))) __attribute__((section(".highcode"))) void ADC_IRQHandler( void ) //adc中断服务程序 { if( ADC_GetITStatus() ) { ADC_ClearITFlag(); if( adclen < 12 ) { abcBuff[adclen] = ADC_ReadConverValue(); ADC_StartUp(); // 作用清除中断标志并开启新一轮采样 } adclen++; } }
int ADC_GetCurrentTS( UINT16 ts_v ) { UINT32 C25_Data[2]; int cal; FLASH_EEPROM_CMD( CMD_GET_ROM_INFO, ROM_CFG_TMP_25C, C25_Data, 0 ); cal = ( ( (ts_v * 1050) + 2048 ) >> 12 ) + ( 1050 >> 1 ); cal = 25 + ((cal - (int)(C25_Data[0]&0xFFFF))*10/14); return ( cal ); }
代码如上,温度测出来一直都是8、9度的样子,室温27度,按理说测出来不应该是27度左右吗,不知道是哪里的问题
CH394: 以太网协议栈芯片
