Need to measure chip temperature and found two implementations of ADC_GetCurrentTS function. The first is:
UINT8 ADC_GetCurrentTS( UINT16 ts_v ) { UINT16 vol_ts; UINT16 D85_tem, D85_vol, D25; vol_ts = (ts_v*1060)>>11; D85_tem = (UINT16)((*((PUINT32)ROM_TMP_85C_ADDR)>>16)&0x00ff); D85_vol = *((PUINT16)ROM_TMP_85C_ADDR); D25 = *((PUINT32)ROM_TMP_25C_ADDR); return ( D85_tem - ( D85_vol - vol_ts + 8 ) * 16 / D25 ); }
The second is:
int ADC_GetCurrentTS( UINT16 ts_v ) { UINT16 vol_ts; UINT16 D85_tem, D85_vol; UINT16 D25_tem, D25_vol; UINT16 temperK; UINT32 temp; UINT8 sum, sumck; int cal; temperK = 64; // mV/16^C vol_ts = (ts_v*1060)>>11; temp = (*((PUINT32)ROM_TMP_25C_ADDR)); D25_tem = temp; D25_vol = (temp>>16); if( D25_vol != 0 ){ // ???????????? // T = T85 + (V-V85)*16/D25 cal = (D25_tem*temperK + vol_ts*16 + (temperK>>1) - D25_vol*16) / temperK ; return ( cal ); } else{ // ???????????? D25_tem temp = (*((PUINT32)ROM_TMP_85C_ADDR)); sum = (UINT8)(temp>>24); // ×???×??? sumck = (UINT8)(temp>>16); sumck += (UINT8)(temp>>8); sumck += (UINT8)temp; if( sum != sumck ) return 0xff; // ???é?????í temperK = D25_tem; // D25_tem = temperK D85_tem = (UINT16)((temp>>16)&0x00ff); D85_vol = (UINT16)temp; // T = T85 + (V-V85)*16/D25 cal = (D85_tem*temperK + vol_ts*16 + (temperK>>1) - D85_vol*16) / temperK ; return ( cal ); } }
Which is better/more correct?
CH592: RISC-V内核BLE5.4无线MCU
