CH573 读取数据问题
手机端发送读数据时, Peripheral例程中的哪个函数被触发回调?修改哪里让它读到我指定想返回的数据,谢谢!
在EVT\EXAM\BLE\Peripheral 的example中,这些读操作最先会调用下面这个函数:
文件: EVT\EXAM\BLE\Peripheral\Profile.c 中的部分代码
static bStatus_t simpleProfile_ReadAttrCB( uint16 connHandle, gattAttribute_t *pAttr,
                            uint8 *pValue, uint16 *pLen, uint16 offset, uint16 maxLen,uint8 method  )
  bStatus_t status = SUCCESS;
  // If attribute permissions require authorization to read, return error
  if ( gattPermitAuthorRead( pAttr->permissions ) )
    // Insufficient authorization
    return ( ATT_ERR_INSUFFICIENT_AUTHOR );
  // Make sure it's not a blob operation (no attributes in the profile are long)
  if ( offset > 0 )
    return ( ATT_ERR_ATTR_NOT_LONG );
  if ( pAttr->type.len == ATT_BT_UUID_SIZE )
    // 16-bit UUID
    uint16 uuid = BUILD_UINT16( pAttr->type.uuid[0], pAttr->type.uuid[1]);
    switch ( uuid )
      // No need for "GATT_SERVICE_UUID" or "GATT_CLIENT_CHAR_CFG_UUID" cases;
      // gattserverapp handles those reads
      // characteristics 1 and 2 have read permissions
      // characteritisc 3 does not have read permissions; therefore it is not
      //   included here
      // characteristic 4 does not have read permissions, but because it
      //   can be sent as a notification, it is included here
      case SIMPLEPROFILE_CHAR1_UUID:
        *pLen = SIMPLEPROFILE_CHAR1_LEN;
        tmos_memcpy( pValue, pAttr->pValue, SIMPLEPROFILE_CHAR1_LEN );
        break;
      case SIMPLEPROFILE_CHAR2_UUID:
        *pLen = SIMPLEPROFILE_CHAR2_LEN;
        tmos_memcpy( pValue, pAttr->pValue, SIMPLEPROFILE_CHAR2_LEN );
        break;
      case SIMPLEPROFILE_CHAR4_UUID:
        *pLen = SIMPLEPROFILE_CHAR4_LEN;
        tmos_memcpy( pValue, pAttr->pValue, SIMPLEPROFILE_CHAR4_LEN );
        break;
      case SIMPLEPROFILE_CHAR5_UUID:
        *pLen = SIMPLEPROFILE_CHAR5_LEN;
        tmos_memcpy( pValue, pAttr->pValue, SIMPLEPROFILE_CHAR5_LEN );
        break;
      default:
        // Should never get here! (characteristics 3 and 4 do not have read permissions)
        *pLen = 0;
        status = ATT_ERR_ATTR_NOT_FOUND;
        break;
