GPIOB_ModeCfg(GPIO_Pin_13 | GPIO_Pin_12, GPIO_ModeIN_PU); #if(I2C_MODE == HOST_MODE) PRINT("IIC Host mode\r\n"); I2C_Init(I2C_Mode_I2C, 400000, I2C_DutyCycle_16_9, I2C_Ack_Enable, I2C_AckAddr_7bit, TxAdderss); while(I2C_GetFlagStatus(I2C_FLAG_BUSY) != RESET); I2C_GenerateSTART(ENABLE); while(!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(RxAdderss, I2C_Direction_Transmitter); while(!I2C_CheckEvent(I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); while(i < 6) { if(I2C_GetFlagStatus(I2C_FLAG_TXE) != RESET) { I2C_SendData(TxData[i]); i++; } } while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_GenerateSTOP(ENABLE); #elif(I2C_MODE == SLAVE_MODE) PRINT("IIC Slave mode\r\n"); I2C_Init(I2C_Mode_I2C, 400000, I2C_DutyCycle_16_9, I2C_Ack_Enable, I2C_AckAddr_7bit, RxAdderss); while(!I2C_CheckEvent(I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED)); while(i < 6) { if(I2C_GetFlagStatus(I2C_FLAG_RXNE) != RESET) { RxData[i] = I2C_ReceiveData(); i++; } } PRINT("RxData:\r\n"); for(i = 0; i < 6; i++) { PRINT("%02x\r\n", RxData[i]); } #endif
例程里面提供的IIC例程如上所示,虽然做了很多改动,但是还是无法读写24C256.不知道错在哪里了,帮忙传一个可用的硬件IIC例程。谢谢
CH390:以太网控制器芯片
