配置PA后,开启广播,广播无法接收,发现RX脚低电平,PB13发射PB14接收,已经在ROLE配置之后,但是发现这两脚在开启广播时都是低电平
?CH58X_BLEInit(?); ??HAL_Init(?); ??GAPRole_ObserverInit(); ??//PA ??GPIOB_ModeCfg(GPIO_Pin_13|GPIO_Pin_14,?GPIO_ModeOut_PP_5mA); ??blePaControlConfig_t?pa_config; ??pa_config.txEnableGPIO?=?(uint32_t)&R32_PB_OUT; ??pa_config.txDisableGPIO?=?(uint32_t)&R32_PB_CLR; ??pa_config.tx_pin?=?GPIO_Pin_13; ??pa_config.rxEnableGPIO?=?(uint32_t)&R32_PB_OUT; ??pa_config.rxDisableGPIO?=?(uint32_t)&R32_PB_CLR; ??pa_config.rx_pin?=?GPIO_Pin_14; ??BLE_PAControlInit(&pa_config);
CH592: RISC-V内核BLE5.4无线MCU
