RT,都是4.0的广播,有没有基于5.0扩展广播带连接的例子
CH32V317: 互联型青稞RISC-V MCU
uint8 adv_type; adv_type = GAP_ADTYPE_EXT_CONN_UNDIRECT;// GAPRole_SetParameter( GAPROLE_ADVERT_DATA, sizeof( advertData_ext ), advertData_ext ); //设置扩展广播 GAPRole_SetParameter(GAPROLE_ADV_EVENT_TYPE,sizeof(uint8_t),&adv_type); GAP_SetParamValue(TGAP_ADV_SECONDARY_PHY,GAP_PHY_VAL_LE_CODED); //125K GAP_SetParamValue(TGAP_ADV_PRIMARY_PHY, GAP_PHY_VAL_LE_CODED);//125K
BLE5.3 使用1M 2M 500K或者 125Kbps通讯 - debugdabiaoge - 博客园 (cnblogs.com)
能加入例程更好
这样是不是通信距离可以提高
通信距离参考:
