下面代码是从参考代码直接复制过来的,只是把通道0改为通道3,增益改了一下,但是执行到
PFIC_EnableIRQ(ADC_IRQn)语句的时候,后面的log就打印不出来了,哪里出错了呢,采用的571k芯片
void Peripheral_Init()
DMA_end=1;
RoughCalib_Value=0;// = ADC_DataCalib_Rough();
GPIOA_ModeCfg(GPIO_Pin_13, GPIO_ModeIN_Floating);
ADC_ExtSingleChSampInit(SampleFreq_3_2, ADC_PGA_1_2);
ADC_ChannelCfg(3);
ADC_AutoConverCycle(192); //采样周期为 (256-192)*16个系统时钟
ADC_DMACfg(ENABLE, (uint16_t)(uint32_t)adcBuff, (uint16_t)(uint32_t)(&adcBuff[40]), ADC_Mode_Single);
PRINT("ADCINIT0\n");
PFIC_EnableIRQ(ADC_IRQn);
PRINT("ADCINIT1\n");
ADC_StartDMA();
