尝试使用582的硬件I2C读取从机寄存器,但是发现会卡在mode_select,不知道该如何解决了
代码参考了:
http://www.wch.cn/index.php/bbs/thread-86122-1.html
http://bbs.eeworld.com.cn/thread-1196656-1-1.html
void?i2c_read_reg(uint8_t?addr,?uint8_t?reg,?uint8_t?data_len,?uint8_t?*data) { ????uint8_t?i?=?0; ????printf("busy1\n"); ????while?(I2C_GetFlagStatus(I2C_FLAG_BUSY)?!=?RESET) ????????; ????printf("busy2\n"); ????I2C_GenerateSTART(ENABLE); ????printf("modeselect1\n"); ????while?(!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT)) ????????; ????printf("modeselect2\n"); ????I2C_Send7bitAddress(addr,?I2C_Direction_Receiver); ????printf("rmodeselect1\n"); ????while?(!I2C_CheckEvent(I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)) ????????; ????printf("rmodeselect2\n"); ????if?(I2C_GetFlagStatus(I2C_FLAG_TXE)?!=?RESET) ????{ ????????printf("send?reg\n"); ????????I2C_SendData(reg); ????} ????printf("rmodeselect1\n"); ????while?(!I2C_CheckEvent(I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)) ????????; ????printf("rmodeselect2\n"); ????if?(data_len?==?1) ????{ ????????I2C_GenerateSTOP(ENABLE); ????????printf("I2C_FLAG_RXNE?1\n"); ????????if?(I2C_GetFlagStatus(I2C_FLAG_RXNE)?!=?RESET) ????????{ ????????????printf("I2C_FLAG_RXNE?2\n"); ????????????*data?=?I2C_ReceiveData(); ????????} ????} ????else ????{ ????????while?(i?<?(data_len)) ????????{ ????????????if?(I2C_GetFlagStatus(I2C_FLAG_RXNE)?!=?RESET) ????????????{ ????????????????data[i]?=?I2C_ReceiveData(); ????????????????i++; ????????????????if?(i?==?(data_len?-?1)) ????????????????{ ????????????????????I2C_GenerateSTOP(ENABLE); ????????????????} ????????????} ????????} ????} } int?main() { ????uint8_t?len?=?0; ????int?err?=?0; ????SetSysClock(CLK_SOURCE_PLL_32MHz); ????/*?配置串口1:先配置IO口模式,再配置串口?*/ ????GPIOA_SetBits(GPIO_Pin_9); ????GPIOA_ModeCfg(GPIO_Pin_8,?GPIO_ModeIN_PU);??????//?RXD-配置上拉输入 ????GPIOA_ModeCfg(GPIO_Pin_9,?GPIO_ModeOut_PP_5mA);?//?TXD-配置推挽输出,注意先让IO口输出高电平 ????UART1_DefInit(); ????printf("hello\n"); ????GPIOB_ModeCfg(GPIO_Pin_13?|?GPIO_Pin_12,?GPIO_ModeIN_PU); ????I2C_SoftwareResetCmd(ENABLE); ????I2C_SoftwareResetCmd(DISABLE); ????I2C_Init(I2C_Mode_I2C,?100000,?I2C_DutyCycle_16_9,?I2C_Ack_Enable,?I2C_AckAddr_7bit,?0x01); ????I2C_StretchClockCmd(ENABLE); ????I2C_Cmd(ENABLE); ????uint8_t?*da; ????i2c_read_reg(0x12,?0x00,?1,?da); ????printf("data:%02x\n",?da); }
根据串口打印信息,是卡在了I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED
从机芯片使用的是qma7981
寄存器如下,代码是读chip-id,在esp32平台测过可以读取,硬件无问题。
