CH32V307 MQTT Example
Hello
i try to compile MQTT example usisng CH32V307EVT
unfortunetly with error.
C:/MRS_DATA/workspace/NetLib/eth_driver.c:217:54: error: 'PHY_STATUS' undeclared (first use in this function)
i can't find where PHY_STATUS is declared - should be in ch32v30x_eth.h (Peripherals ?)
Robert
Such is the case,PHY_STATUS is declared in ch32v30x_eht.h,you can search the key word by "Ctrl+F".
The latest CH32V307EVT download address:   https://www.wch.cn/downloads/CH32V307EVT_ZIP.html  Screenshot-48620a59-2116-4889-bc5c-94a8ea4b1983.png
Hello
It's look like file ch32v30x_eth.h is generated by MRS.
here is screenshoot from 1.7
now i see in 1.8 looks like Your.
i will test
ok. i replaced file ch32v30x_eth.h
from MRS 1.7 to generated by 1.8 and now it compile ok.
Strange from header it's the same 1.0.0
* File Name          : ch32v30x_eth.h
* Author             : WCH
* Version            : V1.0.0
* Date               : 2021/06/06
