CH32V307似乎没有提供串口中断发送的例程。
我自己写了个环形缓冲,但是不知道为什么有稳定性问题。 求助
#define DEBUG_UART_BUF_SIZE 64 #define DEBUG_UART_BUF_MASK DEBUG_UART_BUF_SIZE-1 uint8_t debug_uart_tx_buffer [DEBUG_UART_BUF_SIZE]; //uint8_t debug_uart_rx_buffer [DEBUG_UART_BUF_SIZE]; volatile size_t debug_uart_tx_head; volatile size_t debug_uart_tx_tail; volatile size_t debug_uart_tx_fill; typedef enum { READY = 0,SENDING = 1} UART_TX_Buf_Status; volatile UART_TX_Buf_Status debug_uart_tx_status; void USART_Printf_Init(uint32_t baudrate) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); USART_InitStructure.USART_BaudRate = baudrate; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx; //Tx only as we are doing debug USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); //USART_ITConfig(USART1, USART_IT_TXE, ENABLE); //Enable the TX interrupt, so when the data is taken to the shift register of the // peripheral, we can put in the next byte. NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 14; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); debug_uart_tx_head=0; debug_uart_tx_tail=0; debug_uart_tx_fill=0; debug_uart_tx_status = READY; } void USART1_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast"))); void USART1_IRQHandler(void) { if(USART_GetITStatus(USART1, USART_IT_TXE) == SET) { //Interrupt handler for trasmit //USART1_send_char_from_buffer(); //USART_ITConfig(USART1, USART_IT_TXE, ENABLE); debug_uart_tx_head=(debug_uart_tx_head+1)&DEBUG_UART_BUF_MASK; debug_uart_tx_fill--; if (debug_uart_tx_fill == 0) { // If there is no pending data, stop transmission. USART_ITConfig(USART1, USART_IT_TXE, DISABLE); debug_uart_tx_status = READY; } else{ // If there is still pending data, transmit the next byte. USART_SendData(USART1, debug_uart_tx_buffer[debug_uart_tx_head]); } } } void USART1_putchar(char c){ while (debug_uart_tx_fill >= DEBUG_UART_BUF_SIZE); debug_uart_tx_buffer[debug_uart_tx_tail] = c; debug_uart_tx_tail=(debug_uart_tx_tail+1)&DEBUG_UART_BUF_MASK; debug_uart_tx_fill++; if (debug_uart_tx_status == READY) { debug_uart_tx_status = SENDING; USART_SendData(USART1, debug_uart_tx_buffer[debug_uart_tx_head]); USART_ITConfig(USART1, USART_IT_TXE, ENABLE); } }
具体表现为前面二三十个字节的发送都没问题,但是后来debug_uart_tx_head 跑到tail前面去了,导致乱码。不知道是什么原因。
CH592: RISC-V内核BLE5.4无线MCU
