stm32f103转到ch32f203的时候,是不是所有的系统的.h文件,所有的系统的.c文件,都要替换掉?从代码到目录?
include paths也得重新定义?
hardware\Base.c(473): error: #20: identifier "SysTick_CTRL_CLKSOURCE" is undefined
SysTick->CTRL &= ~SysTick_CTRL_CLKSOURCE; //CLK come from HCLK/8
hardware\Base.c(474): error: #20: identifier "SysTick_CTRL_ENABLE" is undefined
SysTick->CTRL |= SysTick_CTRL_ENABLE;
hardware\Base.c(491): error: #20: identifier "SysTick_CTRL_CLKSOURCE" is undefined
SysTick-> CTRL &= ~SysTick_CTRL_CLKSOURCE;
hardware\Base.c(492): error: #20: identifier "SysTick_CTRL_ENABLE" is undefined
hardware\Base.c(509): error: #20: identifier "SysTick_CTRL_CLKSOURCE" is undefined
hardware\Base.c(510): error: #20: identifier "SysTick_CTRL_ENABLE" is undefined
hardware\Base.c(540): error: #136: struct "" has no field "SR"
do{} while ((IWDG->SR & 0x0003) != 0);
hardware\Base.c(541): error: #136: struct "" has no field "KR"
IWDG->KR = IWDG_WriteAccess_Enable; //0x5555;//使能对IWDG->PR和IWDG->RLR的写
hardware\Base.c(542): error: #136: struct "" has no field "PR"
IWDG->PR = prer; //LSI/32=(40Khz/(4*2^pre))*PLR
hardware\Base.c(543): error: #136: struct "" has no field "RLR"
IWDG->RLR = rlr; //从加载寄存器 IWDG->RLR
hardware\Base.c(544): error: #136: struct "" has no field "KR"
IWDG->KR = 0xAAAA; //reload
hardware\Base.c: 0 warnings, 11 errors
compiling main.c...
.\LIB\inc\usbinc\usb_type.h(13): error: #5: cannot open source input file "debug.h": No such file or directory
#include "debug.h"
user\main.c: 0 warnings, 1 error
compiling usb_desc.c...
#include "debug.h"
hardware\hid\usb_desc.c: 0 warnings, 1 error
compiling usb_endp.c...
#include "debug.h"
hardware\hid\usb_endp.c: 0 warnings, 1 error
compiling usb_prop.c...
#include "debug.h"
hardware\hid\usb_prop.c: 0 warnings, 1 error
compiling usb_pwr.c...
#include "debug.h"
hardware\hid\usb_pwr.c: 0 warnings, 1 error
compiling usb_istr.c...
#include "debug.h"
hardware\hid\usb_istr.c: 0 warnings, 1 error
compiling hw_config.c...
#include "debug.h"
hardware\hid\hw_config.c: 0 warnings, 1 error
compiling usb_core.c...
#include "debug.h"
LIB\src\usbsrc\usb_core.c: 0 warnings, 1 error
compiling usb_init.c...
#include "debug.h"
LIB\src\usbsrc\usb_init.c: 0 warnings, 1 error
compiling usb_int.c...
#include "debug.h"
LIB\src\usbsrc\usb_int.c: 0 warnings, 1 error
compiling usb_mem.c...
#include "debug.h"
LIB\src\usbsrc\usb_mem.c: 0 warnings, 1 error
compiling usb_regs.c...
#include "debug.h"
LIB\src\usbsrc\usb_regs.c: 0 warnings, 1 error
".\output\stm32.axf" - 24 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:06
您好,具体需要根据你用到的外设来看。若你是新开发一个项目,建议你在我们EVT例程的基础上进行开发,若你打算用之前的工程,具体需要根据你用到外设来做改动,某些外设一致,可以不用修改,可直接下载使用;有些外设存在差异,需要你对标准库进行一些移植修改,具体可参考附件FAQ手册,若改动较多,建议你直接在我们EVT工程的基础上进行一个移植,移植改动时需要注意我们寄存器的名称和ST有所不同,我看你的报错可能就是寄存器名称不同以及路径不正确导致的,关于寄存器的写法,具体可参考CH32F203应用手册的寄存器介绍。后面若有问题,可通过邮箱和我沟通(lzs@wch.cn)
CH32F203 应用手册:https://www.wch.cn/downloads/CH32FV2x_V3xRM_PDF.html?
CH32F203 EVT:https://www.wch.cn/downloads/CH32F20xEVT_ZIP.html?
