工程师您好,我想实现简单的流水灯效果(红绿蓝交替),可是灯效太快。通过delay调节不理想,交替时,出现蓝色只亮10个的情况(一共16个灯)。
代码如下,有哪些需要改进的,如果可以,能否提供相关的例程,谢谢
#include "ch32v10x.h" #define T0H 30 #define T1H 60 #define LED_NUM 16 #define DATA_NUM 24 u16 RGB[DATA_NUM *LED_NUM] ; void TIM1_PWMOUTPUT_Init(u16 arr, u16 psc, u16 ccp) { GPIO_InitTypeDef GPIO_InitStruct ; TIM_OCInitTypeDef TIM_OCInitStruct = {0} ; TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct = {0} ; //这个结构体不初始化,无法点亮灯 具体原因未知 //时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //引脚 GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStruct.GPIO_Speed =GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStruct); //TIM1 TIM_TimeBaseInitStruct.TIM_Period = arr - 1; TIM_TimeBaseInitStruct.TIM_Prescaler = psc; TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseInitStruct); //PWM TIM_OCInitStruct.TIM_Pulse = ccp; TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable; // TIM_OCInitStruct.TIM_OutputNState = TIM_OutputNState_Disable; TIM_OCInitStruct.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM1, &TIM_OCInitStruct); TIM_CtrlPWMOutputs(TIM1, ENABLE); TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM1, ENABLE); } void DMA1_Init() { DMA_InitTypeDef DMA_InitStruct ; //如果这个结构体初始化,第一个灯将会最后亮 //时钟 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //DMA DMA_DeInit(DMA1_Channel2); DMA_InitStruct.DMA_PeripheralBaseAddr = (u32)&(TIM1->CH1CVR); DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStruct.DMA_MemoryBaseAddr = (u32)RGB; DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralDST; DMA_InitStruct.DMA_BufferSize = DATA_NUM; DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStruct.DMA_Mode = DMA_Mode_Normal; DMA_InitStruct.DMA_Priority = DMA_Priority_Medium; DMA_InitStruct.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel2, &DMA_InitStruct); TIM_DMACmd(TIM1, TIM_DMA_CC1, ENABLE); } void Reset() { } void COlors(u16 num, u32 rgb) { u8 i,j; for(j = 0; j < num; j++) { for(i = 0; i <8; i++) //GRB格式发送,数组已对GRB编码顺序,改为RGB顺序 { RGB[j * 24 + i + 8] = ((rgb >> 8 >> 8 >> i) & 0x1) ? T1H : T0H; //GREEN RGB[j * 24 + i] = ((rgb >> 8 >> i) & 0x1) ? T1H : T0H; //RED RGB[j * 24 + i +16] = ((rgb >> i) & 0x1) ? T1H : T0H; //BLUE } } } void PWM_Show(u16 num) { DMA_SetCurrDataCounter(DMA1_Channel2, num * DATA_NUM); DMA_Cmd(DMA1_Channel2, ENABLE); TIM_Cmd(TIM1, ENABLE); while(DMA_GetFlagStatus(DMA1_FLAG_TC2) != SET); DMA_Cmd(DMA1_Channel2, DISABLE); TIM_Cmd(TIM1, DISABLE); DMA_ClearFlag(DMA1_FLAG_TC2); } u8 i; int main(void) { Delay_Init(); TIM1_PWMOUTPUT_Init(90, 0, 0); DMA1_Init(); while(1) { for(i = 0; i < 16; i++) { COlors(i+1, 0xff0000); PWM_Show(i+1); Delay_Ms(10); } for(i = 0; i < 16; i++) { COlors(i+1, 0x00ff00); PWM_Show(i+1); Delay_Ms(10); } for(i = 0; i < 16; i++) { COlors(i+1, 0x0000ff); PWM_Show(i+1); Delay_Ms(10); } } }
CH182: 以太网PHY收发器芯片
