GATT_Indication无法正常发送。sdk里面只有找到ble/CyclingSensor中有使用,但测试的发现也无法正常使用
可以在通道4基础上进行修改:
同时检查一下程序中用到noti的地方均修改为Indication。
还是不行,按你说的修改了,但GATT_Indication执行报错。
能帮忙修改一套能成功ind的工程发我吗,谢谢了
个人信息保护,已隐藏
另外,用ind是想用发送成功后的回调,不知道这个机制是否可用
基于Noti的基础进行了修改,已发送至邮箱。
Hi. I'm trying to use "indication" instead of "notification" and it's not working for me. Please send me an example of a working program code for "indication", for the "Peripheral" project.
Hi, please refer to the link in this blog to download the program for modification of "indication". There is a reference program in this link for reference.Download the link at the end of the blog. This program is based on CH582.蓝牙BLE句柄指示\确认(Handle Value Indication\Confirmation)(CH582) - SweetTea_lllpc - 博客园 (cnblogs.com)
I work with the CH582M chip.
I downloaded the example for the "indication" from https://github.com/SweeetTeea/sys/blob/main/BLE_Indication.zip, but it doesn't work either. Here is the debugger log:
11:37:45.928> CH58x_BLE_LIB_V1.50
11:37:45.987> Initialized..
11:37:45.987> Advertising..
11:38:10.334> Conn 1 - Int 24
11:38:10.334> Connected..
11:38:10.898> Update 1 - Int 6
11:38:11.337> Update 1 - Int 24
11:38:14.975> Update 1 - Int 60
11:38:20.345> RSSI -52 dB Conn 1
11:38:30.349> RSSI -45 dB Conn 1
11:38:40.295> RSSI -50 dB Conn 1
11:38:50.310> Char cfg = 2, connHandle = 1, res = 2
11:38:50.310>
11:38:50.310> RSSI -57 dB Conn 1
11:38:55.323> Char cfg = 2, connHandle = 1, res = 2
11:38:55.323>
11:39:00.320> Char cfg = 2, connHandle = 1, res = 2
11:39:00.320>
11:39:00.320> RSSI -59 dB Conn 1
11:39:05.332> Char cfg = 2, connHandle = 1, res = 2
11:39:05.332>
11:39:10.325> Char cfg = 2, connHandle = 1, res = 2
11:39:10.325>
11:39:10.325> RSSI -58 dB Conn 1
11:39:11.265> Disconnected.. Reason:13
11:39:11.265> Advertising..
Where "res = 2" - is the result of execution of GATT_Indication function. For debugging i'm using nRf Connect.
I just searched for the above log printing information and did not see any log information about connhandle. You can re-flash it and try it. I tested here the nrf connection program can be successful, as shown in the figure. You can leave an email address and I will provide you with the code for indication.
connHandle - this is current Connection Handle
