I can not use PA9 as TIM1_CH2: PWM output.
Please help me.
CH339: 7端口多功能USB HUB控制器芯片
Please help me.
Hello, you can see the attachment routine, which realizes four PWM and three complementary
channel outputs
Is there a conflict here?
sure, if you use Serial Port 1, there will be conflicts. If you want to use Serial Port 1, you can map this pin to another pin。
thank you very much.
