uart7 PA6 PA7 串口数据发出?
代码没多少,就是配置一下直接发数据
使用PA6 PA7 发送串口数据
int main(void)
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    Delay_Init();
   // USART_interIni();
    GPIO_InitTypeDef  GPIO_InitStructure = {0};
    USART_InitTypeDef USART_InitStructure = {0};
    NVIC_InitTypeDef  NVIC_InitStructure = {0};
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART7 , ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_AFIO, ENABLE);
    //RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
    GPIO_PinRemapConfig(GPIO_FullRemap_USART7,ENABLE);
    //GPIO_PinRemapConfig(GPIO_PartialRemap_USART7,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
    USART_Init(UART7, &USART_InitStructure);
    USART_ITConfig(UART7, USART_IT_RXNE, DISABLE);
    NVIC_InitStructure.NVIC_IRQChannel = UART7_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    USART_Cmd(UART7, ENABLE);
    //u8 TxBuffer2[] = "#Buffer2 Send from USART3 to USART2 using HalfDuplex Mode!";
    while(1)
        Delay_Ms(1000);
        for(int i=0;i<20;i++)
        USART_SendData(UART7, TxBuffer2[i]);
芯片使用CH32V307VCT6
你好,我看你这边使用的是GPIO_FullRemap_USART7,此为完全重映射,对应引脚为PE12-PE13,如果想映射为PA6-PA7,需开启部分重映射。具体可看手册。另外需要注意的是后面  _1代表的就是部分映射。
可以的,谢谢。
