CH32V208双ADC模式
配置CH32V208外设ADC1和ADC2为同步规则模式,并用DMA搬运数据到内存。从串口数据发现,ADC1可以正确读出数据,而ADC2转换数据一直为0,请问这是什么原因?
#include "debug.h"
/* Global Variable */
u32 TxBuf[1];
u16 Adc_Val[4];
s16 Calibrattion_Val1 = 0;
s16 Calibrattion_Val2 = 0;
void DMA1_Channel1_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
 * @fn      ADC_Function_Init
 * @brief   Initializes ADC collection.
 * @return  none
void ADC_Function_Init(void)
    ADC_InitTypeDef  ADC_InitStructure = {0};
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    ADC_DeInit(ADC1);
    ADC_DeInit(ADC2);
    ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult;
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    ADC_InitStructure.ADC_OutputBuffer = ADC_OutputBuffer_Disable;
    ADC_InitStructure.ADC_Pga = ADC_Pga_1;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_BufferCmd(ADC1, DISABLE); //disable buffer
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
    Calibrattion_Val1 = Get_CalibrationValue(ADC1);
    ADC_BufferCmd(ADC1, ENABLE); //enable buffer
    ADC_Init(ADC2, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_3, 1, ADC_SampleTime_239Cycles5);
    ADC_SoftwareStartConvCmd(ADC2, ENABLE);
    ADC_Cmd(ADC2, ENABLE);
    ADC_BufferCmd(ADC2, DISABLE); //disable buffer
    ADC_ResetCalibration(ADC2);
    while(ADC_GetResetCalibrationStatus(ADC2));
    ADC_StartCalibration(ADC2);
    while(ADC_GetCalibrationStatus(ADC2));
    Calibrattion_Val2 = Get_CalibrationValue(ADC2);
    ADC_BufferCmd(ADC2, ENABLE); //enable buffer
 * @fn      DMA_Tx_Init
 * @brief   Initializes the DMAy Channelx configuration.
 * @param   DMA_CHx - x can be 1 to 7.
 *          ppadr - Peripheral base address.
 *          memadr - Memory base address.
 *          bufsize - DMA channel buffer size.
 * @return  none
void DMA_Tx_Init(DMA_Channel_TypeDef *DMA_CHx, u32 ppadr, u32 memadr, u16 bufsize)
    DMA_InitTypeDef  DMA_InitStructure = {0};
    NVIC_InitTypeDef NVIC_InitStructure = {0};
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA_CHx);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ppadr;
    DMA_InitStructure.DMA_MemoryBaseAddr = memadr;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = bufsize;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA_CHx, &DMA_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    DMA_ITConfig(DMA1_Channel1, DMA_IT_TC | DMA_IT_HT | DMA_IT_TE, ENABLE);
 * @fn      Get_ConversionVal1
 * @brief   Get Conversion Value.
 * @param   val - Sampling value
 * @return  val+Calibrattion_Val - Conversion Value.
u16 Get_ConversionVal1(s16 val)
    if((val + Calibrattion_Val1) < 0)
        return 0;
    if((Calibrattion_Val1 + val) > 4095)
        return 4095;
    return (val + Calibrattion_Val1);
 * @fn      Get_ConversionVal2
u16 Get_ConversionVal2(s16 val)
    if((val + Calibrattion_Val2) < 0)
        return 0;
    if((Calibrattion_Val2 + val) > 4095)
        return 4095;
    return (val + Calibrattion_Val2);
 * @fn      main
 * @brief   Main program.
 * @return  none
int main(void)
    USART_Printf_Init(115200);
    Delay_Init();
    printf("SystemClk:%d\r\n", SystemCoreClock);
    ADC_Function_Init();
    printf("CalibrattionValue1:%d\n", Calibrattion_Val1);
    printf("CalibrattionValue2:%d\n", Calibrattion_Val2);
    DMA_Tx_Init(DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)TxBuf, 1);
    DMA_Cmd(DMA1_Channel1, ENABLE);
    while(1)
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
        Delay_Ms(500);
 * @fn      DMA1_Channel1_IRQHandler
 * @brief   DMA1_Channel1_IRQHandler Interrupt Service Function.
 * @return  none
void DMA1_Channel1_IRQHandler()
    if(DMA_GetITStatus(DMA1_IT_TC1) == SET)
        DMA_ClearITPendingBit(DMA1_IT_GL1);
        Adc_Val[0] = TxBuf[0] & 0xffff;
        Adc_Val[1] = (TxBuf[0] >> 16) & 0xffff;
        printf("ADC1 ch2=%d\r\n", Adc_Val[0]);
        printf("ADC2 ch3=%d\r\n", Adc_Val[1]);
您好,CH32V208系列仅有一个ADC1,因此不能用双ADC模式
请问一下这个问题解决了吗?我也是同样的问题,每次都要重新开一下AD,但每次重开可能采的值就对不上了。
您好,参考2楼回复
