在7个端点配置时,是可以正确识别的,8个端点就无法正确识别了,下面是8个端点的配置:
/* USB配置描述符(高速) */
const UINT8 MyCfgDescr_HS[ ] =
0x09, 0x02, 0x4A, 0x00, 0x01, 0x01, 0x00, 0x80, 0x32,
0x09, 0x04, 0x00, 0x00, 0x08, 0xFF, 0x80, 0x55, 0x00,
0x07, 0x05, 0x81, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x01, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x82, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x02, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x83, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x03, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x84, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
0x07, 0x05, 0x04, 0x02, (UINT8)DEF_USB_HS_EP_SIZE, (UINT8)( DEF_USB_HS_EP_SIZE >> 8 ), 0x00,
