CH582 请教I2C官方示例代码问题
app_i2c.c里i2c_read_from()函数里i2c_master_buffer_length = length - 1;但是中断函数里
/* address sent, ack received */
            if(event & RB_I2C_ADDR) {
                /* ack if more bytes are expected, otherwise nack */
                if (i2c_master_buffer_index + 1 < i2c_master_buffer_length) {
                    I2C_AcknowledgeConfig(ENABLE);
                    I2C_DBG("  address sent\n");
                    I2C_DBG("  ACK next\n");
                } else {
                    //XXX: Should not delay too match before NACK
                    I2C_AcknowledgeConfig(DISABLE);
                    is_nack_sent = true;
                    I2C_DBG("  NACK next\n");
判断条件是i2c_master_buffer_index + 1 < i2c_master_buffer_length,也就是说接收1字节和2字节都是马上I2C_AcknowledgeConfig(DISABLE);3字节开始才I2C_AcknowledgeConfig(ENABLE);
这里的ACK和NACK没有错误吗?我觉得2字节开始就应该要I2C_AcknowledgeConfig(ENABLE);
感谢反馈,如有问题我们会在后续EVT包中更新。
